Subs to Factory Stereo
Had a question on how to install subs and amp to a factory head unit. The car is a 2012 Mazda 6. Wondering what I what need to do this and if it is possible.
Thanks in advance. |
You will need:
Line out converter RCA cables power and ground wire some wire for a remote amplifier subwoofer box. completely doable and fairly simple. |
Originally Posted by neophyte
(Post 343076)
You will need:
Audio Control has a series of processors with bass restoration. If your Mazda has a multi-speaker system then you either need to tap the full range signal on the largest drivers or use a summing device that combines all of the speaker outputs into a single pair.
Originally Posted by keep_hope_alive
(Post 343082)
for the majority of them you will need both. the bass processor is a nice thing to have. any kind of crossovers, processors, equalizers, will add to a stereo if you set them up properly. it is just usually people are looking for the cheapest route when they do not give a budget which is why I did not mention it.
(Post 343122)
how much of a budget do you have for the processor?
this is a decent one that wont break the bank. nvx bass reoconstructer but there are better ones out there. and this one does not require the line out converter. you can use high level inputs. but it is pricey. audiocontrol |
(Post 343127)
