Wiring halo projector headlights .
I just recently installed my halo projector lights and theres 2 extra red wires which i figured is for the halo rigns but i dont know where im gonna wire em to .. anyone who has actually worked on this before can maybe give me a hint on to where i can wire it to .. i would greatly appreciate it .. TNX YALL
RE: Wiring halo projector headlights .
Its best to hook them to a 5v power source so the led's wont burn out.
When I had them on my 97 I wired them to my corner bulbs #194/#168 and spliced into those wires for the power on each side. Its easy, just make sure you protect the bare/soldered wires. |
What you should do, which is what I did, is wire them to the Headlight fuse under the hood.
Well, thats where the fuse box is located for 94-97 Accords. |
5v is still too much, they will work but will burn out with time. Depending on the color they should be getting 3.3v. But the kit he has prolly already has a resistor to each LED, so you should hook those wires up to a 12v source. Then either wire a switch or wire then to the headlights or parking lights circut.
