Wiring halo projector headlights .
Old Sep 6, 2008 | 12:49 PM
RuthlezzFL1P's Avatar
Default Wiring halo projector headlights .
I just recently installed my halo projector lights and theres 2 extra red wires which i figured is for the halo rigns but i dont know where im gonna wire em to .. anyone who has actually worked on this before can maybe give me a hint on to where i can wire it to .. i would greatly appreciate it .. TNX YALL
Old Sep 10, 2008 | 12:02 AM
19Accord97
Default RE: Wiring halo projector headlights .
Its best to hook them to a 5v power source so the led's wont burn out.
When I had them on my 97 I wired them to my corner bulbs #194/#168 and spliced into those wires for the power on each side. Its easy, just make sure you protect the bare/soldered wires.
Old Sep 10, 2008 | 11:08 AM
nrmskate's Avatar
What you should do, which is what I did, is wire them to the Headlight fuse under the hood.
Well, thats where the fuse box is located for 94-97 Accords.
Old Sep 10, 2008 | 02:59 PM
t00fatt's Avatar
5v is still too much, they will work but will burn out with time. Depending on the color they should be getting 3.3v. But the kit he has prolly already has a resistor to each LED, so you should hook those wires up to a 12v source. Then either wire a switch or wire then to the headlights or parking lights circut.
petef23a
Jan 3, 2010 10:47 AM
accordking
Jun 6, 2009 08:10 PM
accordking
May 12, 2009 07:10 PM
QnzBurna28
Oct 17, 2008 07:06 PM
ikethegreat
Dec 8, 2007 11:16 PM
