XM Radio id
Old Feb 28, 2008 | 05:31 PM
hblevine
Default XM Radio id
Hi - I'm new to the forum.
I just got a brand new 2008 Accord EX-L 6 Cyl. Absolutely fantastic car.
This one came with XM, and I'm on the 3 month feebie plan. I'd like to upgrade, but I'm told I need to tune to channel zero to get the XM Radio ID.
Well, the radio only goes down to channel one. Does anyone know how to get the code from this radio?
could it be defective?
Thanks
Howie
Old Feb 28, 2008 | 06:13 PM
sir_nasty's Avatar
Default RE: XM Radio id
either go into the menu settings and get it or use the remote and push 0
Old Feb 28, 2008 | 07:57 PM
hblevine
The menu settings only control balance, fade, bass, etc. And, there is no remote. It's the factory installed radio (270w - no nav).
When I put the selection *** into the CHANNEL LIST mode, it does not show anything below channel 1.
Very odd.
Old Feb 28, 2008 | 09:45 PM
gomarlins3's Avatar
I just tried it in mine and mine went to zero and showed my code. '08 coupe.
Old Feb 29, 2008 | 12:02 PM
catbert430's Avatar
I just tried mine as well. It goes from channel 001 to 000 and shows the code. I have the same radio (EX-L V6 sedan premium 270w system w/o nav).
Just use the large **** to change the channel while listening to XM.
In a month or so, you will get a mailing from XM trying to get you to subscribe when the 3-month trial is over. They have all the data needed.
Old Feb 29, 2008 | 12:32 PM
smaglik's Avatar
does it in my 07....
Old Feb 29, 2008 | 04:09 PM
hblevine
I have a feeling it is a defective radio.
(Either that, or it's been hacked and I have free XM - but that's just a pipe-dream)
I get all the stations, so it's probably in the 3 month trial now - so there is no need to rush back to the dealer.
I was able to do it on my previous Accord - 2005.
Thanks.
Old Mar 1, 2008 | 04:56 PM
hblevine
I finally got it. It seems that "Channel List" mode is different from "Channel" mode.
To switch between Channel mode and Category mode I had to hold in the TITLE button. That allowed me to dial down to '0'
Thanks
Old May 13, 2014 | 06:42 PM
greyghost14's Avatar
Default xm radio
I have 09 Accord ,xm radio fades in and out.need quick fix besides cutting car it off and on.
Old May 13, 2014 | 08:19 PM
keep_hope_alive's Avatar
XM radio shouldn't "fade". it can cut out and cut back in but no fading.
if it cuts out, keep in mind that XM satellites are above the Equator at all times and any obstruction to the south can cause issues. XM uses repeaters on the ground to help with coverage but not for all areas. when it cuts out pay attention to what's south and that may identify the issue being just XM and not the radio or car.
djaycardona
Nov 26, 2013 04:07 PM
GMANCRX
Jul 15, 2013 02:50 PM
RecMK5
Feb 13, 2009 06:33 AM
Jeff247
Mar 28, 2007 04:22 PM
vaughnsimon
May 21, 2005 05:36 AM
