how do i clean the whole motor?
Old Oct 3, 2008 | 03:44 PM
mrbaysick's Avatar
Default how do i clean the whole motor?
So yeah..its looking a bit dirty under my hood..Is there a way to clean it to make it all brand new looking again?
Old Oct 3, 2008 | 03:45 PM
finch13's Avatar
Default RE: how do i clean the whole motor?
Use my sig and search for engine bay and cleaning.
Old Oct 3, 2008 | 08:44 PM
klrspz's Avatar
doesn't really look that bad to me
Old Oct 3, 2008 | 08:46 PM
yeah that looks mint compared to what my f22 looked like
Old Oct 4, 2008 | 09:10 AM
19Accord97
Dang, that looks like you just cleaned it to me! I dont know if I would ever clean my engine. To nervous about spraying a stream of water all over the engine.
Old Oct 10, 2008 | 12:53 PM
Lx A cord's Avatar
pressure wash it?
Old Oct 10, 2008 | 01:23 PM
RTexasF's Avatar
Super Member
Spray some degreaser on it then blast it off at the car wash. Have a can of WD40 with you. In case it won't start spray WD40 inside the distributor cap and fire it up. In 40 yearsof doing thisI've only had two no starts (both with distributors)and the WD40 worked both times. Once it's dry go to Auto Zone, get a can of CD2 engine detailer & spray it down.......everything. Crank the engine and drive a bit to build some heat. Once complete wipe off any runs. It will look better than new. I have my own pressure washer and charge $45 for this.
Old Oct 24, 2008 | 01:34 PM
thewraith's Avatar
Or just get some engine cleaner- warm the car up, spray it with foaming engine cleaner and scrub the tough spots. Then let it sit, hose it down, then spray foaming tire cleaner all over and drive your car around. Then open your bay and look
Old Oct 27, 2008 | 10:22 AM
Jchou
RtexasF is there a more detailed "DIY" for the engine detailing. Picture or video would help. Some visual such as circling the area safe for spraying..hosing..with the degreaser and CD2.
Old Oct 27, 2008 | 08:37 PM
1993accordEX
watch out for the fuel injectors if you use degreaser. it ate the seals on mine
