How to remove glue
Old May 1, 2008 | 09:57 PM
HORSEPOWERJUNKIE2007's Avatar
Default How to remove glue
hey, i was supergluing my decal back on and some of it spilled around the rim NOW you can see the marks of superglue,does anyone know what will remove it
Old May 2, 2008 | 01:15 PM
falkore24's Avatar
Default RE: How to remove glue
Superglue?!? ...... paint remover will take it off.
Old May 2, 2008 | 01:57 PM
finch13's Avatar
Won't paint remover also remove the paint on the wheel?
Old May 2, 2008 | 02:01 PM
sir_nasty's Avatar
you could try some mineral spirits (available at most hardware stores, commonly used inside...) to start with, and/or you can use paint remover on a rag then lightly rub the glue only.
Old May 5, 2008 | 10:40 AM
falkore24's Avatar
I was joking! The paint remover can take off the paint under the superglue, thus getting rid of the glue ..... but then you might want to re-paint the part.
I don't know what can take off super-glue without hurting the paint. I'll take a look online to see if I find anything.
EDIT: http://www.supergluecorp.com/removingsuperglue.html
These guys say that nail polish remover will work. I say, try it with a Q-tip and roll the swab on the glue only .... wipe clean with a wet rag every few minutes to neutralize the acid.
Old May 5, 2008 | 11:40 AM
sir_nasty's Avatar
well falkore your joke is true.... you can remove it with paint remover as long as you're gentle with a rag, it also works well for tree sap (I've done it personally on my car and we've done it on new cars on the lot...) and it didn't hurt the paint at all.
Old May 5, 2008 | 12:00 PM
Just dont pour Coke Cola on the wheel..the whole wheel will disappear...
Old May 5, 2008 | 02:22 PM
xpieceofcralpx's Avatar
Almost A Senior Member
goo gone! get it at wal mart =) in the cleaning supplies section at the grocery side of the store haha
Old May 5, 2008 | 05:17 PM
RTexasF's Avatar
Super Member
Old Sep 14, 2008 | 05:03 PM
YoungLemon's Avatar
this is bad, u should of used silicone to put the emblem back. i think u would need to wetsand it and then repaint the rim back.
