I NEED HELP PLEASE!!!!!!!!!
Old Apr 18, 2008 | 03:54 PM
Whitefoxx's Avatar
Default I NEED HELP PLEASE!!!!!!!!!
Hey wass uP every one, I have a big time problem, my front right headlight has a layer of something wierd. I got Mothers deatiling package that came with a Claybar, detailing spray, and the wax. I did everything like I read and it still doesnt go away. The really wierd thing is as soon as the detailing solution is sprayed on, it goes away but as soon as I wipe it the plastic layers reapear PLEASE HELP!!!!!!! what can I do Here are some pics Hope this helps.
I tryed loading the pics here if you cant see them CLICK ON THE LINK BELOW THE PICS ARE IN THE GALLERY HELP ME PLEASE, I will do anything to get rid of this crap, you can even call me 1-818-683-3228 Nick for advise, anything please help guys thanx
Old Apr 18, 2008 | 05:07 PM
sir_nasty's Avatar
Default RE: I NEED HELP PLEASE!!!!!!!!!
If that's on the outside I'd try wetsanding it with a really soft sand paper
Old Apr 18, 2008 | 07:08 PM
Daver's Avatar
also, if you look on autogeek they have a headlight cleaning kit, it basically buffs it down with a very mild abrasive, same as the sandpaper maybe a little less guess work
Old Apr 18, 2008 | 07:12 PM
RTexasF's Avatar
Super Member
I agree, wetsanding is your only hope and it still may not work. If I knew how I would offer advice. Find a shop or someone that knows howand give it a go. It will have to be buffed afterward to see if it worked or not.
Old Apr 18, 2008 | 07:50 PM
Daver's Avatar
also something else that came to mind is on my old mustang (yeah I am originally a ford guy) the headlights did not drain, somehow they would let water in but no drain.. I had to take the assembly out and wash the inside of them, before putting them back I drilled a few small holes in the lower sections of the headlight unit, which fixed it pretty much. so make sure it is something on the outside, either way you will get the same yellowish tinting of the lense..
Old Apr 18, 2008 | 09:47 PM
Whitefoxx's Avatar
thanx a lot guys, I guess thats all I can do is wet sand it I found this web site check this out http://www.myfto.co.uk/peeling.htm but its not here in the us. You guys think this will work if I got those same items (just the us versions)???
Old Apr 19, 2008 | 10:44 PM
Jesstzn's Avatar
Here is a link that might help you out .. I have done this on many cars.
http://forums.vwvortex.com/zerothread?id=2485084
Old Sep 14, 2008 | 05:10 PM
YoungLemon's Avatar
i would do these steps in order.
1.wash it
2.claybar
3.wet sand using lightest to rougher. start from 2000 then use 1000
4.plastic x
5.polish
6.wax
Old Sep 15, 2008 | 09:50 AM
falkore24's Avatar
^^^ you're suggesting sanding in the wrong order. Also, calybar is unnecessary if wetsanding .... maybe after a polish, then clay and re-polish.
Old Sep 15, 2008 | 01:05 PM
RTexasF's Avatar
Super Member
Here's a thought:
http://www.mdwholesale.com/
