LEDs
well i was hoping i could set it up to just turn on with the car. possible at all?
i also purchased some led turn signals for my mirrors as far as hooking those up does anyone know where i could get some general direction?
You can wire the leds into an ignition hot wire, one goes to the radio and another one should be on the ignition switch.
The turn signals would have to be wired to the turn signals in the headlights I would think, or some point after the flasher.
anyone have any idea what the colors of these wires are and how i could locate them? pictures or anything would be helpful. i'd say i'm pretty intuitive when it comes to electronics i just need a shove in the right direction.
well the wire on your led signals.just get a big roll of that!somewhere on the forum there is instructions on how to take of your mirror.i have those tried to hook em up and gave up.u need a good snake to get the wire through the mirror.GL
You dont need to post the same question twice. And it doesnt even make sense to put it in the detailing forum.
I think I would do research before buying stuff like this. All you need to do is wire it into the cigarette lighter. 12V. Already fused. Comes on when the car is on/off when the car is off.
As far as wiring the turn signals, the mirrors should already have wire pigtails sticking through the hole. Just butt splice those wires to longer wires and feed them through the firewall (pleanty of places to do this) and then splice them into the turn signal wires leading to the bulb. That would be the easiest way, and the power draw from each mirror is probably like 3W max.
Thanks for the input guys. and yeah i know i didn't mean to post it in detailing that was my bad so i tried to correct it.
anywho, finding the fuse box you say is located on either side of the dash.. is that fairly simple to access etc? and those led strips will really draw 20-30 watts?
i didnt know leds drew that much power. well when you open up the fuse box on either side, look at the diagram on the back of the panel and find something that turns on with the ignition (for example i used the power side view mirrors). then remove the fuse, and using a test light find which side hot. you need to put your positive wire from the leds into the FUSED side, not the hot side. otherwise the fuse would be useless. then just ground the negative wire and BAM you're good
i would actually recommend you wire it to a switch, so you can turn them on and off. this is a little more complicated, but heres an easy diagram. just replace the battery with fuse you will be tapping into
