Tar,Any suggestions on how to clean
Old Mar 14, 2008 | 07:22 PM
RondaTheHonda
Default Tar,Any suggestions on how to clean
Hey How's it goin Im new to theH.A.Forum, I hope i learn alot from you accord fans out ther,Im Means nice to meet you all, I have a 02' Accord which belonged to my sister up until recently i bought it off of her and during the duration of her ownership my brother inlaw painted the drive way with the black paint(tar i think) so it happend to get on the car i took one of the drops off a couple days ago and it left a forrestgreen mark i think it stained the car surface i was wondering on how to get it off without painting the car or even not make it visable any suggestions would be great thanks [:-]
Old Mar 14, 2008 | 08:13 PM
Briggz's Avatar
Almost A Senior Member
Default RE: Tar,Any suggestions on how to clean
Honestly... try bug and tar remover... you can find it anywhere. Pretty much every department store or auto store will have it. It's cheap, and it works. I had weird gunk on my car last summer that nothing even touched, until I tried bug and tar remover. It works miracles.
Old Mar 15, 2008 | 09:06 AM
RTexasF's Avatar
Super Member
Look for this at Pep Boys, WallyMart or auto parts stores. Clickfor larger image.
[IMG]local://upfiles/127/77894EBAEDC045A1BAA7D13F832F88B7.jpg[/IMG]
Old Mar 15, 2008 | 11:12 AM
RondaTheHonda
Thanks Guys ill go and check these productd soon as the weather gets a bit better you know Canada [:'(]lol to much of that white stuff up here[8D]once i try it ill let you know how it works thanks again.
Old Mar 15, 2008 | 04:28 PM
sir_nasty's Avatar
looks like someone has named their car the same as mine... *L*
Old Mar 15, 2008 | 08:25 PM
RTexasF's Avatar
Super Member
Use cotton towels to remove the tar. The tar remover will take off every bit of wax so make sure that you seal or wax once the tar is gone.
Old Mar 15, 2008 | 08:44 PM
RondaTheHonda
Lmao her names actully Amy. But my Girl friend thought RondaTheHonda Sounded better kinda does lol. so wax after i remove the tar? what do you suggest is a good wax?
Old Mar 15, 2008 | 08:52 PM
RTexasF's Avatar
Super Member
Pick one! You will recieve any many responses as there are waxes. Any tar remover will strip EVERYTHING off of the paint so it must be protected afterwards. Check this thread for a super easy to use product with showcar results. Our administrator does use it on his showcar as do many peeps here on their daily driver......including yours truly.
https://www.hondaaccordforum.com/Wet...m_17070/tm.htm
Old Mar 16, 2008 | 02:16 AM
lgetz's Avatar
Used gasoline in a spray bottle to get some especially heavy tar off. As mentioned above use wax afterwards. Good Luck.
Old Mar 16, 2008 | 12:08 PM
ihrtmyhonda
i use moc products on my car...in this case try liquid wonder
