Wet Paint
Old Jul 27, 2008 | 06:29 PM
  #111
mgerencs
Default RE: Wet Paint
Has anyone applied wp with a pc and how well did it work?
Old Jul 27, 2008 | 08:25 PM
  #112
RTexasF's Avatar
Super Member
Exceptional look as a matter of fact. Start with a clean dry surface. Using a white finishing pad spread the product on speed 3 (putWP on the surface and the pad) then go to speed 6 for a short time until WP almost disappears. If you go to 6 and it slings product slow down to 3 and work it some more. It may take a panel or two togetthe knack for it.You can feel when you have worked it enough. Wipe it down with a microfiber towel and proceed. It is called burnishing the finish and the look will knock your tallywacker in the dirt!
Old Jul 28, 2008 | 07:29 AM
  #113
mgerencs
Thank you RTexasF. I had a feeling you'd answer . By the way, will wp do any correction if a cutting pad is used?
Old Jul 28, 2008 | 07:41 AM
  #114
RTexasF's Avatar
Super Member
Yes and no. It will do correction with a rotary and a wool pad. In all honesty I haven't tried it with a PC or Cyclo. It's worth a try with an orange or yellow pad for light correction.
Old Jul 28, 2008 | 10:51 AM
  #115
mgerencs
Thanks for your time. I will do the white pad and pc this week. If I give the orange pad a shot onmy girlfriends vehicle I'll let you know how it went.
Old Jul 28, 2008 | 03:37 PM
  #116
RTexasF's Avatar
Super Member
They do make wool pads for the PC and I have some. I've only used them as backing for a microfiber or terrycloth bonnet thus far. If I've got heavy correcting I break out the Cyclo and an abrasive polish.
Old Jul 28, 2008 | 03:43 PM
  #117
RTexasF's Avatar
Super Member
ORIGINAL: mgerencs
You are welcome. Keep the pressure light on the PC, you want as much rotation as possible when burnishing. Smaller pads work even better allowing more rotation.
Old Jul 28, 2008 | 06:56 PM
  #118
mgerencs
I have some 4" lake country on order. Expect them tomorrow or Wednesday. I'll try them. Thanks again for the advice.
Old Jul 28, 2008 | 08:42 PM
  #119
RTexasF's Avatar
Super Member
Do you have the smaller backing plate?
Old Jul 29, 2008 | 05:35 AM
  #120
mgerencs
Yes I will. It's coming with the pads.
