DIY Answers. This section is for the staff of HAF to post detailed DIYs in response to the requests by the members.
2013 Accord - Buzzing from the engine compartment after the engine is turned off
Old Dec 23, 2012 | 01:47 PM
Default 2013 Accord - Buzzing from the engine compartment after the engine is turned off
Honda has a technical service bulletin regarding this for the Accords with the L4 engines.
Note: Technical service bulletins are not recalls, unless specifically noted as related to a recall; generally, they are to help Honda technicians with known issues. Issues noted in TSBs do not necessary apply to all vehicles. Normal warranty applies.
Honda TSB 12-085
Buzz Coming From the Engine Compartment After the Engine Is Turned Off
Applies To: 2013 Accord 2-Door – From 1HGCT1...DA000001 thru 1HGCT1...DA000123
2013 Accord 4-Door – From 1HGCR2...DA000001 thru 1HGCR2...DA021824
2013 Accord 4-Door – VIN begins with JHM
SYMPTOM
Buzzing is heard coming from the engine compartment after the engine is turned off.
PROBABLE CAUSE
The PCM operates the VTC solenoid with the ignition key turned to the OFF position.
CORRECTIVE ACTION
Update the PGM-FI software in the PCM.
aaron185
Dec 3, 2019 12:20 PM
Accord9573
Jun 26, 2012 12:23 PM
mister_floyd
Aug 30, 2010 10:08 PM
msm2010
Mar 26, 2010 01:37 PM
bchambers05
Dec 8, 2006 11:53 PM
