Setting Base Idle speed
I was sure I had written this up before, but I can't find it...
This applies to Accords of the 1990 - 2002 range. Someone who knows more about earlier Accords, feel free to modify the range of model years. Background: Honda's idle-control system is a little bit finicky. It should be set up this way because otherwise the ECU will try to fight against any other adjustments. The "BASE" idle is a low idle, too low for normal operation. But it's the basis for the IACV to operate properly within it's control range. Fix problems first: - find & fix any vacuum leaks - clean the throttle body bore & throttle plate - clean the IACV and FITV (beginning 1998 there is no FITV) - make sure the throttle plate closes completely - - (mechanical stop-screw is only used to prevent it from wedging stuck closed) - make sure the throttle cable goes a bit slack - - (throttle cable is never used to adjust idle) - make sure the cooling system has no air pockets (they confuse the system) Find the parts first. - Idle-Air Control Valve (IACV) is usually bolted to the back of the intake manifold. - Idle-Air bypass screw is just above the throttle bore, recessed in a hole in the throttle body, it's usually a brass screw with a straight slot for a screwdriver. It has an O-ring that should be checked as a potential vacuum leak. Procedure: - Warm the engine up completely. - Turn off all loads (AC, blowers, defoggers, stereo, EVERYTHING) - Up to 1997; Unplug wire harness from IACV (engine will almost stall) - - For 1998-2002; unplug the EVAP purge valve (see post #13 below). - Adjust the idle-air bypass valve for 550 RPM - - (PLEASE anyone with specific RPM for certain years chime in) - Turn the engine off & plug everything back in Now you should force the system to re-learn the idle behavior: - Allow the engine to cool down completely - Reset your ECU (different years pull various fuses) - Start the engine without touching the gas pedal - Allow it to run & warm up completely without touching the gas pedal That should do it... |
Now for some specifics...
For 1998-2002 Accord, there is no FITV. That function is built into the newer version of the IACV. Reset the ECU by pulling fuse #13 in the fusebox at the right-end of the dashboard (near the right door hinges). |
For 2003 & newer (especially later when they have motorized throttles) the procedure is driven by Honda's proprietary scan-tool. Never done it, don't know whether there's a do-it-yourself way around that.
Someone please chime in if they know whether this applies to the V-6 cars or not...
This may be an unneccessary question however I am going to ask anyway. Is the process the same for all engines(4 cyl) or are there more specific steps for a f23a1 engine? I am trying my hardest to not sound too much like a noob ;).
It's good for the F23A1, including the reminder in post #2 that your engine doesn't have an FITV.
I should add that some F22B1's do not have an FITV. My 97 does not have one.
The factory manual for the 97 accords says 550 +/- 50rpm for F22B1 and B2 620 +/- 50rpm for F22B5 and F20B3 When setting the idle when the IACV is not connected. When plugging it back in and restarting the engine it should be 700 +/- 50rpm for F22B1 and B2 770 +/- 50rpm for F22B5 and F20B3 |
Hello!
1 Attachment(s)
Originally Posted by jcollins6
(Post 235111)
Welcome to the HAF.. :) |
I want to than all of you for your support! The car is running very good, and i think it was the adjustment for the idle that did the trick. What a great bunch of people! I am so glad i joined this forum! Again, I thank you all for your support, Jerry.
will be using this info ASAP...thanks guys
| All times are GMT -5. The time now is 12:04 AM. |
