DIY Answers. This section is for the staff of HAF to post detailed DIYs in response to the requests by the members.
Setting Base Idle speed
Old Mar 12, 2011 | 07:32 PM
Default Setting Base Idle speed
I was sure I had written this up before, but I can't find it...
This applies to Accords of the 1990 - 2002 range. Someone who knows more about earlier Accords, feel free to modify the range of model years.
Background:
Honda's idle-control system is a little bit finicky. It should be set up this way because otherwise the ECU will try to fight against any other adjustments. The "BASE" idle is a low idle, too low for normal operation. But it's the basis for the IACV to operate properly within it's control range.
Fix problems first:
- find & fix any vacuum leaks
- clean the throttle body bore & throttle plate
- clean the IACV and FITV (beginning 1998 there is no FITV)
- make sure the throttle plate closes completely
- - (mechanical stop-screw is only used to prevent it from wedging stuck closed)
- make sure the throttle cable goes a bit slack
- - (throttle cable is never used to adjust idle)
- make sure the cooling system has no air pockets (they confuse the system)
Find the parts first.
- Idle-Air Control Valve (IACV) is usually bolted to the back of the intake manifold.
- Idle-Air bypass screw is just above the throttle bore, recessed in a hole in the throttle body, it's usually a brass screw with a straight slot for a screwdriver. It has an O-ring that should be checked as a potential vacuum leak.
Procedure:
- Warm the engine up completely.
- Turn off all loads (AC, blowers, defoggers, stereo, EVERYTHING)
- Up to 1997; Unplug wire harness from IACV (engine will almost stall)
- - For 1998-2002; unplug the EVAP purge valve (see post #13 below).
- Adjust the idle-air bypass valve for 550 RPM
- - (PLEASE anyone with specific RPM for certain years chime in)
- Turn the engine off & plug everything back in
Now you should force the system to re-learn the idle behavior:
- Allow the engine to cool down completely
- Reset your ECU (different years pull various fuses)
- Start the engine without touching the gas pedal
- Allow it to run & warm up completely without touching the gas pedal
That should do it...
Old Mar 12, 2011 | 07:33 PM
Now for some specifics...
For 1998-2002 Accord, there is no FITV. That function is built into the newer version of the IACV.
Reset the ECU by pulling fuse #13 in the fusebox at the right-end of the dashboard (near the right door hinges).
Old Mar 12, 2011 | 07:36 PM
For 2003 & newer (especially later when they have motorized throttles) the procedure is driven by Honda's proprietary scan-tool. Never done it, don't know whether there's a do-it-yourself way around that.
Old Mar 12, 2011 | 07:37 PM
Someone please chime in if they know whether this applies to the V-6 cars or not...
Old Mar 23, 2011 | 09:10 AM
jcollins6's Avatar
This may be an unneccessary question however I am going to ask anyway. Is the process the same for all engines(4 cyl) or are there more specific steps for a f23a1 engine? I am trying my hardest to not sound too much like a noob .
Old Mar 23, 2011 | 11:15 AM
It's good for the F23A1, including the reminder in post #2 that your engine doesn't have an FITV.
Old Nov 21, 2012 | 01:34 PM
RobinsonRicer's Avatar
I should add that some F22B1's do not have an FITV. My 97 does not have one.
The factory manual for the 97 accords says
550 +/- 50rpm for F22B1 and B2
620 +/- 50rpm for F22B5 and F20B3
When setting the idle when the IACV is not connected.
When plugging it back in and restarting the engine it should be
700 +/- 50rpm for F22B1 and B2
770 +/- 50rpm for F22B5 and F20B3
Old Nov 23, 2012 | 01:27 PM
Talking Hello!
But Jcollins, with your one post, you are a Noob..
Welcome to the HAF..
Attached Thumbnails Setting Base Idle speed-526512_10151278647314989_2039005446_n.jpg
Old Dec 20, 2012 | 07:03 AM
jjtjr's Avatar
I want to than all of you for your support! The car is running very good, and i think it was the adjustment for the idle that did the trick. What a great bunch of people! I am so glad i joined this forum! Again, I thank you all for your support, Jerry.
Old Mar 23, 2014 | 09:43 PM
HondaAccordEXUSMC's Avatar
will be using this info ASAP...thanks guys
