|Stainless |Steel |Braided |Stuff
Old Dec 16, 2008 | 01:29 AM
clutch811's Avatar
Default |Stainless |Steel |Braided |Stuff
anyone familiar with where one can purchase stainless steel braided hoses for things such as radiator hoses, power steering, fuel, etc|? thanks
Old Dec 16, 2008 | 05:33 AM
cjdm98's Avatar
Default RE: |Stainless |Steel |Braided |Stuff
There are kits out there to braid the lines yourself,and also at my job(advance auto) we sell braided fuel lines,and such,but is made by Holley. Hope this helpls
Old Dec 16, 2008 | 09:11 AM
TAS auto has brake, clutch and fuel. Never seen a braided radiator line...............on any car I dont think, never mind an Accord.
Old Dec 16, 2008 | 09:33 AM
finch13's Avatar
TAS also just released an adapter to convert the line over to AN fittings so you can replaced the fuel line to the tank as well... braided... psh... only good for brake lines. The P/S line has a braided steel core line on the pressure side (one running to the back of the engine and to the rack) with a rubber tubing enclosure in case it bursts. Fuel doesn't get above 40 psi, so also not impending explosion or expansion. The actuating rod on the clutch is going to bend before you burst the line so waste of money there... unless its all for dress up.
Old Dec 16, 2008 | 09:39 AM
falkore24's Avatar
Actually SS brake and clutch lines DO firm up pedal feel.
Old Dec 16, 2008 | 09:43 AM
finch13's Avatar
hydraulic lines controlled by pedals will always benefit from a rigid line, because the pressure will always increase until you stop pressing the pedal or blow seals or blow lines.
whitemexsicken
Nov 30, 2013 01:26 PM
mangler
Mar 6, 2013 09:57 PM
fopokev07
Nov 30, 2007 08:41 AM
JStoops
15
Aug 21, 2007 04:36 PM
beets442
Nov 21, 2005 10:56 AM
