02 EX 4 cylinder
Old Oct 20, 2008 | 10:27 PM
crhny77
Default 02 EX 4 cylinder
Just seein if anyone has any answers to my probs.
I am getting cylinder 1 - 4 misfire codes.
The check engine light is on solid when i am driving on the highway but then flashes when idling.
The engine is very rough when idling and exhaust is sputtering.
I have changed the oil, oil filter, Antifreeze, plugs, wires, cap, rotor, pcv valve, & air filter today and it actually seems to be worse.
In addition to that the engine fan only operates when the ac is on. It will get very hot otherwise & have an abs light on.
The car has about 90,000 miles on it.
Any help is appreciated.
Old Oct 23, 2008 | 10:23 AM
Antarctica's Avatar
Default RE: 02 EX 4 cylinder
Did you gap your plugs right? Are your wires installed correctly? Connecting the wires wrong can cause a load of problems. How's your O2 sensor? Have you even tried diagnosing your CEL codes? That would be my first step. Doesn't your car have two engine fans, one for cooling and another for A/C? What's the last thing you did before this load of problems? Did it overheat or did you rev it up too high? You need to troubleshoot your problems more. Post back when you have some answers. ABS is a braking problem. Seriously, what the f**k did you do to your car?
Old Oct 23, 2008 | 02:31 PM
What kind of new plugs? Lots of stories about Bosch plugs NOT working good in Honda.
Use NGK. 2nd choice = Denso.
Old Oct 29, 2008 | 08:29 AM
KevinAccord's Avatar
did you try a compression test on the cylinders? O2 sensor? injectors? fuel pump?
Old Oct 30, 2008 | 12:09 AM
[quote]ORIGINAL: JimBlake
Also agree with Jim on this choice of plugs , NGK or Denso...
Chris Jameson
Feb 19, 2013 06:39 AM
STINKA621
Mar 9, 2009 07:53 AM
PJ_STYLES_95AccordEx
Oct 24, 2007 09:58 PM
aso432
Oct 23, 2005 10:41 PM
gonecrazy
Oct 12, 2005 11:57 PM
