03 Accord V6 engine replacement
Hello all, I'm a new member here and I have a situation I've been trying to solve for quite some time now. I apologize if there is something out there like this already. The situation is as follows:
I have an 03 accord V6 manual and the engine has failed on me. According to the Honda dealership, the engine is seized and is unable to be turned manually therefore I need to replace the engine. They told me it'd be $3,500 and I said bump that I'll do it myself. The car has 108,000 miles on it. The car wont start and according to a couple of other mechanics the ECU was going bad which leads me to believe that may also have had an effect on the engine problem. That being said I figured I might as well just do an engine swap. From the research I've gathered I decided I'd try to swap with the Acura TL (04-08) engine considering people have said that it'd fit with no modifications. I'm not a car guru and so I'm still learning a lot as well as doing research, therefore I want to be 100% sure of what I'm getting into with this project. My biggest concern is if I'd have to buy an ECU to match the Acura engine, would I need to get it tuned, and if there is anything else I should replace in the process? On a side note, I love my honda and I'd love to turn it into a nice sleeper. It's currently stock with the exception of a AEM V2 CAI... Thanks in Advance! |
Suggest purchasing the exact engine you are replacing to avoid any possibility of surprises.
Check car-part.com and ebay for used engines. good luck |
Thank you, I appreciate your reply. So you don't think it'd be a good idea to shoot for a swap? what would you suggest in regards to improving my performance if not by means of an engine swap?
Originally Posted by byuboi
(Post 305467)
Originally Posted by shipo
(Post 305471)
The best/cheapest way to improve the performance of your car is to sell it and buy a faster car.
I have access to tools and a shop in which to work on my car. I am not looking for the cheapest way, I'm looking for someone who has information regarding improving the performance of my vehicle. TexasHonda has given me a safer option which I acknowledged, does anyone have any other options or ideas not involving selling my vehicle or keeping the stock parts currently available?
