03 Accord V6 engine replacement
Old Dec 16, 2012 | 10:53 AM
byuboi's Avatar
Default 03 Accord V6 engine replacement
Hello all, I'm a new member here and I have a situation I've been trying to solve for quite some time now. I apologize if there is something out there like this already. The situation is as follows:
I have an 03 accord V6 manual and the engine has failed on me. According to the Honda dealership, the engine is seized and is unable to be turned manually therefore I need to replace the engine. They told me it'd be $3,500 and I said bump that I'll do it myself. The car has 108,000 miles on it. The car wont start and according to a couple of other mechanics the ECU was going bad which leads me to believe that may also have had an effect on the engine problem.
That being said I figured I might as well just do an engine swap. From the research I've gathered I decided I'd try to swap with the Acura TL (04-08) engine considering people have said that it'd fit with no modifications.
I'm not a car guru and so I'm still learning a lot as well as doing research, therefore I want to be 100% sure of what I'm getting into with this project. My biggest concern is if I'd have to buy an ECU to match the Acura engine, would I need to get it tuned, and if there is anything else I should replace in the process?
On a side note, I love my honda and I'd love to turn it into a nice sleeper. It's currently stock with the exception of a AEM V2 CAI... Thanks in Advance!
Old Dec 16, 2012 | 03:37 PM
Suggest purchasing the exact engine you are replacing to avoid any possibility of surprises.
Check car-part.com and ebay for used engines.
Old Dec 16, 2012 | 06:34 PM
byuboi's Avatar
Thank you, I appreciate your reply. So you don't think it'd be a good idea to shoot for a swap? what would you suggest in regards to improving my performance if not by means of an engine swap?
Old Dec 16, 2012 | 06:49 PM
shipo's Avatar
The best/cheapest way to improve the performance of your car is to sell it and buy a faster car.
Old Dec 17, 2012 | 03:48 PM
byuboi's Avatar
If I wanted to go that route I would have done so prior to purchasing the car I currently have. I purchased this year and model with a specific purpose in mind and the best/cheapest way is irrelevant, therefore your response doesn't help me in the least, but thank you I do appreciate your input.
Old Dec 17, 2012 | 03:59 PM
byuboi's Avatar
I have access to tools and a shop in which to work on my car. I am not looking for the cheapest way, I'm looking for someone who has information regarding improving the performance of my vehicle. TexasHonda has given me a safer option which I acknowledged, does anyone have any other options or ideas not involving selling my vehicle or keeping the stock parts currently available?
s4m222
Dec 22, 2009 12:31 PM
thedaveman89
Nov 21, 2008 12:47 PM
taengok
Aug 30, 2008 11:18 PM
Thwh
Apr 10, 2005 09:28 PM
