1990 accord 2.2 engine
Old Dec 12, 2008 | 06:03 PM
kirklm's Avatar
Default 1990 accord 2.2 engine
i have a 2.2 engine in my garage that i would like to rebuild. im green on knowing
bout rebuildn so if i could get some specs or advice on some sites i would b greatful.
Old Dec 12, 2008 | 06:34 PM
finch13's Avatar
Default RE: 1990 accord 2.2 engine
What the purpose of the rebuild? Just to replace worn internals or to build it for more power?
Live2Rice is in the process of building a nice normally aspirated H22... he has a thread in the off topic section with the specs.
Old Dec 12, 2008 | 06:35 PM
You'll have to be more specific on what information you are looking for. Are you just doing a stock rebuild or what? and what specs are you looking for.
Old Dec 12, 2008 | 06:37 PM
finch13's Avatar
since you said 2.2L... check out f22parts.com
Old Dec 12, 2008 | 06:38 PM
He has a F22a, Bisimoto is the king of F22as, for the top shop challenge he got 360hp out of one N/A. I dont think this member is looking to build for horsepower though.
Old Dec 13, 2008 | 06:32 PM
kirklm's Avatar
im lookn for more horsepower. im not sure what or how to start or how much it will cost. im a while from startn the rebuild on the engine. but the aim is more hp. and tryn to find a car that
i can put it in. just startn the research. my buddy says start with the specs on boring it out.
i appriciate all the info i can get.
Old Dec 13, 2008 | 06:36 PM
89mm is a good bore, if you are serious about big hp you would probably want to resleeve it. but you could make decent hp on a stock set up. The main thing you need to decide is do you want to keep it naturally aspirated or go forced induction/nitrous.
Old Dec 13, 2008 | 07:04 PM
kirklm's Avatar
no nitro for now. naturally asp. is what im aimn for.whats 89mm? the thickness of the cylindr walls.
Old Dec 13, 2008 | 07:08 PM
no the diameter of the cylinder from wall to wall. You need to decide up front if you ever want to turbo, supercharge, or nitrous, you cant build N/A then decide later you want to add nitrous, cause you will blow it up real quick.
Bisimoto is the king of F22s. He has gotten 360hp out of them naturally aspirated which is pretty much unheard of. Granted it was pretty much just a dyno motor that only had to be run full out once then it could blow up. But either way check out his site: bisimoto.com
Old Dec 13, 2008 | 07:15 PM
kirklm's Avatar
with this engine im not tryn for nitro or supprcharg.
