1996 Honda Accord Clutch Leak
I need help identifying the part my clutch is leaking from?
Ok, can you give a pic of the part :shrug: or at least a better description.
Probably the master cylinder.
Stick your head under the dash and using a flashlight, look at the upper left area above the clutch pedal. Follow the clutch rod (from the pedal) to the firewall. What you're looking for is a trail of fluid leaking out the rear of the clutch master cylinder. If you see the trail, you've found your leak. That's where the leak was in my 97 Accord. |
