1996 Honda Accord Clutch Leak
Old May 19, 2017 | 03:40 PM
PolitoHonda96's Avatar
Default 1996 Honda Accord Clutch Leak
I need help identifying the part my clutch is leaking from?
Old May 19, 2017 | 06:31 PM
Ok, can you give a pic of the part or at least a better description.
Old May 20, 2017 | 06:36 AM
The Toecutter's Avatar
Probably the master cylinder.
Stick your head under the dash and using a flashlight, look at the upper left area above the clutch pedal. Follow the clutch rod (from the pedal) to the firewall. What you're looking for is a trail of fluid leaking out the rear of the clutch master cylinder. If you see the trail, you've found your leak. That's where the leak was in my 97 Accord.
19962door
Jan 27, 2017 07:46 AM
Ryoku92
Feb 16, 2016 01:05 PM
curvenut
Apr 12, 2014 11:15 PM
accord6266
Feb 7, 2013 12:33 AM
tamb
Jul 21, 2006 01:05 AM
