1996 Clutch Issue
Old Dec 26, 2012 | 01:43 AM
accord6266's Avatar
Default 1996 Clutch Issue
hey i just bought a 96 accord and i put gear oil in it after i replaced the clutch pump and the slave, but wenn i bleed it aftera minute or two it my cluch goes soft ...what can i do to fix this ? anyone
Old Dec 26, 2012 | 08:11 AM
If the pedal is going soft after a few minutes then it sounds like there is a leak - air getting into - in the system. Double check the work you did and be sure all connections are tight.
Old Dec 28, 2012 | 10:14 PM
accord6266's Avatar
@poorman212...i had i found the problem ...the gear oil i put in swoul up all the rubber parts and basicly destroyed it ..so i replaced theparts and this time i put the manual clutch fluid and its running like a champ...is there anything i can do to make it faster . i raced a couple of vtec hondas and i beat all of them..i wanna make it faster??? any help..
Old Dec 29, 2012 | 04:51 AM
UhOh's Avatar
Originally Posted by accord6266
...the gear oil i put in swoul up all the rubber parts and basicly destroyed it ...
Help us out a bit and tell us specifically what oil you tried that swelled up the rubber gaskets. Thanks
Old Dec 30, 2012 | 06:42 PM
accord6266's Avatar
I put Lucas high performance gear oil
Old Dec 30, 2012 | 10:55 PM
I'm still confused:
Was the problem from the fluid you put into the manual transmission? Or was the problem the fluid you put in the hydraulic system in the clutch master cylinder?
Old Dec 30, 2012 | 11:21 PM
accord6266's Avatar
the fluid i put in my hydraulic system in the clutch master cylinder
Old Dec 31, 2012 | 02:43 PM
HondaBrat's Avatar
Suppose to use brake fluid in the hydraulic clutch system.
Old Dec 31, 2012 | 03:43 PM
accord6266's Avatar
Ik that nowlol.. But now im trying to bleed it again and ma pedal went deAd I don't know why
Old Jan 1, 2013 | 06:49 AM
Are you sure you got all of the oil out? It might have ate the seals again?
