1996 Honda Accord Clutch Leak
Probably the master cylinder.
Stick your head under the dash and using a flashlight, look at the upper left area above the clutch pedal. Follow the clutch rod (from the pedal) to the firewall. What you're looking for is a trail of fluid leaking out the rear of the clutch master cylinder. If you see the trail, you've found your leak. That's where the leak was in my 97 Accord.
or at least a better description.
