5-15 minute delay
Old Feb 9, 2013 | 08:23 PM
Roger Drake's Avatar
Default 5-15 minute delay
I have a 1994 Accord that if you stall it with the clutch or turn it off and try to re-start right away it has no fuel pressure. walk away for 5-15 minutes and it will start. I just replaced the clutch and after hooking up the battery it wouldnt fire. came back 15 min later, fired right up.?????
Old Feb 15, 2013 | 11:28 PM
go-part's Avatar
Former Sponsor
It sounds like you are having ECM issues.
It is common for a a hot ecu to not allow starting until it cools down.
http://www.ecmtogo.com/ECMTips2.htm
Old Feb 16, 2013 | 09:58 AM
Suggest checking for fuel delivery by listening carefully for fuel pump, when ignition is turned to On. If it's missing, the main fuel relay or fuel pump could be the problem.
mclasser
Mar 28, 2013 07:29 AM
justdriveRRC
May 5, 2011 04:33 PM
Sep 11, 2009 09:42 AM
somerustspots
Oct 22, 2008 06:09 PM
miki
Aug 11, 2006 03:59 AM
