6th gen (98 - 02) automatic transmission filter?
is there really a filter in the transmission? I've been hearing around places that there is but to replace it or so you have to completely remove/rebuild the transmission. On some other place I've been hearing that there isn't at all a transmission filter. I'm just asking is there or is there not a filter for the transmission? If there is when do you guys recommend to replace it or do what ever to it?
RE: 6th gen (98 - 02) automatic transmission filter?
There is no transmission filter for your accord.
ORIGINAL: superballz00 There is no transmission filter for your accord. If you wanted to add a filter to it that would be the place to do it. |
ORIGINAL: Chiovnidca ORIGINAL: superballz00 There is no transmission filter for your accord. If you wanted to add a filter to it that would be the place to do it. |
so far, all I know is that my transmission wasn't part of the recall for the accords to have the transmission replaced
wasnt it for all accord autos in that gen?
ORIGINAL: superballz00 Do you mean the transmission replacement by honda for the defected ones known to fail often from 98-02? |
The orginal design of 6th gen honda auto transmissions had the filter (acutally a strainer screen) that was inside the transmission and not user serviceable. It is my understanding that the reman units have an inline filter on the cooling lines that needs to be changed on a regular basis.
