At 70mph I hear the engine make noise
When I get to about 70mph I hear the negine make like a revving noise(if that makes sense) and I could swear the gas pedal gets a little harder to push. Is it me? or is this something?
RE: At 70mph I hear the engine make noise
there are lots of possible causes why engine makes a noise. it would be best to check all the honda engine parts such as the check timing; valve timing; check if the engine overheats; check the bearing, wristpin slap or failing knock sensor. keep us posted of what other things did you found out.. good luck
I din't find anything else out, I know I can't go over 70mph, dont know why the engine wont accelerate more
Did you purchase this car used? It almost sounds like it has been reprogrammed to cut out at 70mph. The last 93 accord I drove (probably back in 93 or 94) cut off at 123mph.
When you get to 70 does the engine and rpm's continue to increase but your speed doesn't? If so that's a slipping tranny usually...
rpm does increase, or at least it sounds like it, but i stay at 70mph
sounds like a tranny issue.
