At 70mph I hear the engine make noise
Old Jun 19, 2007 | 01:35 PM
Jcaleno's Avatar
Default At 70mph I hear the engine make noise
When I get to about 70mph I hear the negine make like a revving noise(if that makes sense) and I could swear the gas pedal gets a little harder to push. Is it me? or is this something?
Old Jun 26, 2007 | 07:47 PM
zam17's Avatar
Default RE: At 70mph I hear the engine make noise
there are lots of possible causes why engine makes a noise. it would be best to check all the honda engine parts such as the check timing; valve timing; check if the engine overheats; check the bearing, wristpin slap or failing knock sensor. keep us posted of what other things did you found out.. good luck
Old Jun 26, 2007 | 08:20 PM
Jcaleno's Avatar
I din't find anything else out, I know I can't go over 70mph, dont know why the engine wont accelerate more
Old Jun 27, 2007 | 07:50 AM
Sinecure's Avatar
Did you purchase this car used? It almost sounds like it has been reprogrammed to cut out at 70mph. The last 93 accord I drove (probably back in 93 or 94) cut off at 123mph.
Old Jun 28, 2007 | 10:57 AM
sir_nasty's Avatar
When you get to 70 does the engine and rpm's continue to increase but your speed doesn't? If so that's a slipping tranny usually...
Old Jul 2, 2007 | 11:24 PM
Jcaleno's Avatar
rpm does increase, or at least it sounds like it, but i stay at 70mph
Old Jul 3, 2007 | 02:24 PM
smaglik's Avatar
sounds like a tranny issue.
pancho88
Mar 4, 2012 02:07 PM
juncho
Sep 19, 2008 08:20 AM
rstiffen
May 7, 2008 12:09 PM
JustinFanatic
Sep 2, 2006 07:36 PM
theycallmerickjames
Jan 6, 2006 06:52 AM
