Hear air escaping as engine turns
Old Mar 4, 2012 | 11:34 AM
pancho88's Avatar
Default Hear air escaping as engine turns
Hey guys, in the middle of a timing belt job, and I noticed something that seemed not quite right. I took one spark plug out (#4 cylinder) and I was rotating the engine via the crank to get everything to TDC. As I was rotating (the other 3 spark plugs still in) I hear air escaping from somewhere. Albeit slowly, I can still hear it. Am I crazy or is that something that isn't really supposed to happen?
Old Mar 4, 2012 | 12:05 PM
The sound of air escaping could be from the other 3 cylinders that have compression. Compressed air is probably leaving through the exhaust valve when it opens, which is normal.
To make turning the engine by hand easier, you may want to remove all the spark plugs.
Old Mar 4, 2012 | 12:28 PM
pancho88's Avatar
ok thanks for the reply. I was quick to jump to "this shouldn't be happening". Just a little paranoid i guess.
Old Mar 4, 2012 | 02:07 PM
At really low RPM (like rotating the engine by hand) the piston rings are far from airtight. Pretty normal to hear air escaping from the combustion chamber into the crankcase.
JkillaAcc02
Apr 14, 2008 10:42 AM
Jcaleno
Jul 3, 2007 02:24 PM
JustinFanatic
Sep 2, 2006 07:36 PM
Nimoxp
Aug 17, 2006 02:55 AM
theycallmerickjames
Jan 6, 2006 06:52 AM
