88 Accord Aftermarket Camshaft Replacement
Old Apr 16, 2009 | 10:31 PM
88lxaccord3152's Avatar
Post 88 Accord Aftermarket Camshaft Replacement
I want to replace my stock cam with an aftermarket cam. I am wanting it to sound like those cameros that idle different. What kind of cam would I need to get and what brand would be the best? About how much would it cost to have someone replace it for me?
Old Apr 25, 2009 | 11:30 AM
streetlimitz89's Avatar
to sound like a camaro ... just take 1 plug wire off and it wil have tht idle like iit all they are is just a larger cam lobe causing a rough idle
Old May 4, 2009 | 08:28 PM
masudkarim
Default 88 Accord Aftermarket Camshaft Replacement
Camshaft drives, whether gears, belts or chains are also able to even out wear,
... Aftermarket timing belts may be used to alter engine performance. ... Gates
- Timing Belt Replacement Guide with illustration of V6 timing ... When changing
the timing belt on a 90 Honda Accord do you have to get the .
CR123
Dec 8, 2024 09:06 PM
bossie
Mar 29, 2021 11:17 PM
kris_loehr
Dec 19, 2008 07:20 PM
deserthonda
May 12, 2006 12:12 AM
