89 accord lx swap question
Old Apr 7, 2006 | 02:10 AM
jbirdy958
Default 89 accord lx swap question
I'm new to the honda scene, since I have had mainly toyotas, but I recently got an 89 accord lx for $150. It runs fine, but I just want to get some more power in there. Are there any engines that are "easier" to swap in than others or are there even any I could put in there? Any help would be greatly appreciated. Thanks ahead of time!
Old Apr 7, 2006 | 06:19 AM
lightshow's Avatar
Default RE: 89 accord lx swap question
any motor can be swapped into any car. those old accords run devilishly mean with an h22a though
Old Apr 7, 2006 | 10:52 AM
marbro's Avatar
Yeah, if you want a good n/a car the jdm h22a thats 220hp would be the one to hunt for.
If you want a turbo setup and you get that 220hp engine youre going to have to swap out the pistons for lower compression ones and most likely sleeve the block if you run more then 8 psi of boost, and if anyone tells you to boost that jdm engine without changing the pistons, its 11:1 compression pistons in it...... you wont be running boost for long
Old Apr 7, 2006 | 07:19 PM
jbirdy958
Awesome! Thanks for the replies. I'm now on the hunt for an h22a I'll keep everybody posted on how my swap goes.
Jrmemo
Jan 27, 2013 07:41 PM
hondahead23
May 9, 2011 08:55 AM
mfskarphedin
Jun 6, 2010 09:33 PM
Clutch32192
May 24, 2010 04:36 PM
