92 17MPG???
Hey, i just realized while reading threw posts, that other 90-93's get 30+MPG. Well If i drive nicley :) i get about 17-18. Im no mechanic but somethings got to be wrong. Any suggestions?
Oh 92 LX If that helps. |
RE: 92 17MPG???
are you getting that 17-18 highway? cause if thats where youre getting it, yes, there is a problem
RE: 92 17MPG???
last time the car had a tune up was ???
RE: 92 17MPG???
A $1 bottle of Super Tech fuel injector cleaner wouldnt hurt.
RE: 92 17MPG???
I have tried all sorts of additives. Fuel and Oil. Stupid me, i just picked up my Haynes book and its in the troubleshooting section. I think it might be the Ignition Timing. Any others suggestions.
RE: 92 17MPG???
test your o2 sensors and replace if needed
check your air filter for oil blow by check PCV valve for proper operation (should rattle) run some sea foam through it test your fuel pressure and correct if it is too low or too high is your transmission operating correctly? are your brakes dragging? |
RE: 92 17MPG???
Air filter is fine, i just put in a K&N with SRI. (gas milage was same before intake.)
Just checked PCV rattles and sucks fine. Trannys good. Brakes fine. How would i go about checking sensors, And fuel pressure? |
RE: 92 17MPG???
personally I would replace your o2 sensor if you are up there in milage....
you need a fuel pressure guage to test fuel pressure....DH can you show him? I am not sure how to do it on a 94...(never had to) does your engine rattle when it is warmed up? If so it may be time for a valve adjustment |
RE: 92 17MPG???
I think it is the sensor, i just checked it and i think its bad.
Engine shakes at idle, but thats the rear motor mount, replacing it soon. |
RE: 92 17MPG???
tune up ?????
| All times are GMT -5. The time now is 08:13 AM. |
