92 17MPG???
Old Oct 27, 2006 | 12:21 AM
ncsgoofy's Avatar
Default 92 17MPG???
Hey, i just realized while reading threw posts, that other 90-93's get 30+MPG. Well If i drive nicley i get about 17-18. Im no mechanic but somethings got to be wrong. Any suggestions?
Oh 92 LX If that helps.
Old Oct 27, 2006 | 02:48 AM
marbro's Avatar
Default RE: 92 17MPG???
are you getting that 17-18 highway? cause if thats where youre getting it, yes, there is a problem
Old Oct 27, 2006 | 03:47 AM
deserthonda's Avatar
last time the car had a tune up was ???
Old Oct 27, 2006 | 03:55 PM
19Accord97
A $1 bottle of Super Tech fuel injector cleaner wouldnt hurt.
Old Oct 27, 2006 | 09:12 PM
ncsgoofy's Avatar
I have tried all sorts of additives. Fuel and Oil. Stupid me, i just picked up my Haynes book and its in the troubleshooting section. I think it might be the Ignition Timing. Any others suggestions.
Old Oct 27, 2006 | 10:20 PM
YeuEmMaiMai's Avatar
test your o2 sensors and replace if needed
check your air filter for oil blow by
check PCV valve for proper operation (should rattle)
run some sea foam through it
test your fuel pressure and correct if it is too low or too high
is your transmission operating correctly?
are your brakes dragging?
Old Oct 27, 2006 | 10:59 PM
ncsgoofy's Avatar
Air filter is fine, i just put in a K&N with SRI. (gas milage was same before intake.)
Just checked PCV rattles and sucks fine.
Trannys good.
Brakes fine.
How would i go about checking sensors, And fuel pressure?
Old Oct 28, 2006 | 04:21 PM
personally I would replace your o2 sensor if you are up there in milage....
you need a fuel pressure guage to test fuel pressure....DH can you show him? I am not sure how to do it on a 94...(never had to)
does your engine rattle when it is warmed up? If so it may be time for a valve adjustment
Old Oct 28, 2006 | 04:42 PM
ncsgoofy's Avatar
I think it is the sensor, i just checked it and i think its bad.
Engine shakes at idle, but thats the rear motor mount, replacing it soon.
Old Oct 29, 2006 | 02:12 PM
tune up ?????
