93 Accord EX clutch issues...
Just picked up this Accord about 3 weeks ago and it's been running great...that is...until today when the clutch started acting up. Now I'm quite sure the 93 accords have a hydraulic clutch. Maybe even all the 4th gen accords do...that I'm not entirely sure of. But, there's a lot of play from all the way out till half way in; and after I release the clutch it sticks at about half way out for just a second then releases the rest of the way.
HELP ME PLEASE! Thank you! |
RE: 93 Accord EX clutch issues...
sounds like you got a leak in the system, ( air in the system ), chk the master and slave cylinders for leaks,
master under the dash at the clutch pedal rod, slave at the tranny ,, if eithr leaks replace as needed our DIY section has a write up on it . if neither leaks chk the lines and hose,, if all ok, bleed the sytem and retry it |
ORIGINAL: deserthonda sounds like you got a leak in the system, ( air in the system ), chk the master and slave cylinders for leaks, master under the dash at the clutch pedal rod, slave at the tranny ,, if eithr leaks replace as needed our DIY section has a write up on it . if neither leaks chk the lines and hose,, if all ok, bleed the sytem and retry it |
