93 Accord EX clutch issues...
Old Feb 22, 2007 | 01:45 AM
dirtMccord's Avatar
Default 93 Accord EX clutch issues...
Just picked up this Accord about 3 weeks ago and it's been running great...that is...until today when the clutch started acting up. Now I'm quite sure the 93 accords have a hydraulic clutch. Maybe even all the 4th gen accords do...that I'm not entirely sure of. But, there's a lot of play from all the way out till half way in; and after I release the clutch it sticks at about half way out for just a second then releases the rest of the way.
HELP ME PLEASE! Thank you!
Old Feb 22, 2007 | 03:15 AM
deserthonda's Avatar
Default RE: 93 Accord EX clutch issues...
sounds like you got a leak in the system, ( air in the system ), chk the master and slave cylinders for leaks,
master under the dash at the clutch pedal rod, slave at the tranny ,, if eithr leaks replace as needed our DIY section has a write up on it .
if neither leaks chk the lines and hose,, if all ok, bleed the sytem and retry it
Old Feb 22, 2007 | 12:16 PM
dirtMccord's Avatar
ORIGINAL: deserthonda
Thanks deserthonda! I had my mechanic buddy take a look and it turns out it's the slave cylinder. Pretty sure all is well, it's a cheap fix
vetski179
Feb 24, 2015 04:26 PM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
sassyboo2
Oct 30, 2006 01:54 AM
tamb
Jul 21, 2006 01:05 AM
