94 accord Lx engine swap
Old Nov 25, 2011 | 01:20 PM
Eazysc's Avatar
Default 94 accord Lx engine swap
I have a 94 honda accord lx and just did a engine swap for a odb2 engine out a 96 honda accord its not cranking because of the crank sensor i believe what all do i have to do to convert the a 96 engine to work in a 94.
Old Nov 25, 2011 | 07:24 PM
g22cd5's Avatar
Supper Moderator
so you swapped your f22b2 (non vtec) for what obd2 accord engine? f22b1 (vtec) ?? Or another f22b2? What ecu are you usein? Also if your new engine is obd2 and your car is obd1 you will need a obd2 to obd1 conversion harness.
Old Nov 29, 2011 | 10:54 AM
Eazysc's Avatar
I swapped it for another another f22b2...no v tecs... and i got to see wat kind of ecu i have will i have to change that too.
Old Nov 29, 2011 | 01:53 PM
g22cd5's Avatar
Supper Moderator
if the f22b2 was from a 96 then it's obd2. So you will need to buy a obd2 to obd1 conversion harness. You can use your original ecu since it was a obd1 f22b2 ecu. With the harness that should fix your issue
Old Nov 29, 2011 | 03:56 PM
Eazysc's Avatar
Also what type of distributor should i use 94 distributor and coil pack or the 96 distributor.
Old Nov 29, 2011 | 04:07 PM
g22cd5's Avatar
Supper Moderator
is the 94 external or internal coil?
Also is the 96 internal or external?
If you don't know you can tell by looking at them. If the dizzy is internal it will only have 4 spark wires going to the head. If it's external you will have 5 wires coming off the dizzy.
See how the dizzy on the left only has 4 spots for wires? That internal.
The one with 5 spots is external.
You can use either or. But it would be easier to use the dizzy that is meant for your car. There will be no added steps to make it work. Plug and play.
Old Nov 29, 2011 | 04:24 PM
Eazysc's Avatar
I have a 94 external coil thats on there now
Old Nov 29, 2011 | 04:54 PM
g22cd5's Avatar
Supper Moderator
it would be easier to stay external. But you can use either or. So don't get rid of the 96 dizzy you might need it later on. I swapped my f22a to a internal coil b/c my coil pack went bad. I had my f22b1 dizzy laying around and use it. You just have to put a 30amp fuse in the socket that use to plug into the coil pack on your wiring harness
Old Nov 29, 2011 | 08:44 PM
Eazysc's Avatar
thanks for the info hope this works we been trying to figure out why it wasnt cranking for 2 months now til one day we saw that crank sencor plug and found out 94's dont have crank sensors
Old Sep 21, 2012 | 08:38 PM
Slidesquad240's Avatar
I did this same swap but my car runs it just won't rev past 2000 rpm?
D-Rod33
Nov 2, 2011 07:38 AM
hondahead23
May 9, 2011 08:55 AM
mfskarphedin
Jun 6, 2010 09:33 PM
StatzFinest
Feb 10, 2008 11:32 AM
