95 accord ex building engine?
Old Dec 10, 2008 | 12:32 PM
95exvtec's Avatar
Default 95 accord ex building engine?
what could i do to make my car faster with about 1300$
Old Dec 10, 2008 | 12:48 PM
finch13's Avatar
Default RE: 95 accord ex building engine?
Live2Rice will know...
You could swap in a H22 with that money
Old Dec 10, 2008 | 12:55 PM
95exvtec's Avatar
so what should i do about it bein automatic? i was gonna convert it to a 5 speed
Old Dec 10, 2008 | 01:04 PM
finch13's Avatar
I bet you could find an H22 and a 5speed tranny for a grand and use the remaining $300 to get the engine in top shape before swapping it in.
Old Dec 10, 2008 | 01:12 PM
95exvtec's Avatar
do you think i could build my stock f22b by any chance to make a noticeable difference in power
Old Dec 10, 2008 | 01:24 PM
finch13's Avatar
You would spend more money getting the F22 to the same power as a standard H22
Old Dec 10, 2008 | 01:26 PM
95exvtec's Avatar
i found a motor on ebay its a non vtec f22b dohc for 600$ i can get the 5 speed transmission for 300$
Old Dec 10, 2008 | 01:32 PM
finch13's Avatar
They never made a F22B DOHC.
They made:
- F22B1 SOHC 16V 2.2L VTEC
- F22B2 SOHC 16V 2.2L non-VTEC
and
- F20A/B/C, none of which were offered in the US and one of them was DOHC.
You will make more power with an H and it's an easy swap.
Old Dec 10, 2008 | 01:51 PM
Wrong finch, F22B is a JDM non-vtec DOHC motor that makes 160hp if I recall correctly.
$1300 a little short for any major modifications. If you do all the work yourself you MIGHT be able to pull off a H22 swap, doubt able that you could pull off a H22 swap and 5spd conversion for that much.
I know a few people that are into modifying the F22, but not many. Just saw a G22 build(H22 head on a F22 block).
Old Dec 10, 2008 | 01:57 PM
finch13's Avatar
Then teh Wikipedia has failed meh.
Still think the H22 can be DIY'ed for under $1300
