98 AV6 EX Sedan Swap
Old May 1, 2008 | 01:53 PM
Bobster
Default 98 AV6 EX Sedan Swap
J32A2 / headers, 05 TL rear sway bar, lowered via Eibach prokit with camber kits around( 1.5" drop ).
Old May 1, 2008 | 03:35 PM
falkore24's Avatar
Default RE: 98 AV6 EX Sedan Swap
What is the point of this thread?
Old May 1, 2008 | 03:47 PM
Bobster
ORIGINAL: falkore24
Just to show there are other possibilities for power other than bolt ons. But if that escapes you, just delete it.
Old May 1, 2008 | 04:28 PM
00AccordLX5spd's Avatar
Registered User
How much did the swap cost you? Are you still running the stock transmission? Need some more pics!
Old May 1, 2008 | 04:32 PM
falkore24's Avatar
^^^ Is that like "more tea" from Alice in Wonderland?
What kind of gain did you get from the A2 manifold? Dyno'd?
Old May 1, 2008 | 05:39 PM
HORSEPOWERJUNKIE2007's Avatar
sooooooooooo i'm lost....did you do some type of engine swap of some sort?this thread makes no sense?...
Old May 1, 2008 | 05:41 PM
falkore24's Avatar
ORIGINAL: Bobster
ORIGINAL: falkore24
You know ..... swapping the exhaust manifold is still a bolt-on even if you sourced an OEM part.
Old May 1, 2008 | 06:44 PM
Bobster
I swapped a J32A2 = Type S
Im still using the auto trans but wished i had went with the 6 speed from acura.
The swap cost me about $600 cause i onlt paid $250 for the motor/harness with papers saying 53k miles.
I didnt count all the labor and research i did.
[IMG]local://upfiles/16310/775AF600E68D4319BDD17C6A338EF16E.jpg[/IMG]
Old May 1, 2008 | 09:37 PM
was your accord a V6 originally???or a I-4?
Old May 1, 2008 | 10:20 PM
Bobster
ORIGINAL: HORSEPOWERJUNKIE2007
yes, i wouldnt do a 4 cyl
