99 Accord v6 Crazy ECM?
Hi All, craziest thing on my 99 Accord EXV6. It will only run if my code reader CABLE is plugged to the OBD plug. Not the code reader itself, just the cable. Cranks and runs fine, dies when I unplug the cable. If I unplug cable while off, it will not start. If i turn ignition to ON position without cable, it makes a weird clicking noise. As long as the cable is in, with or without the reader doesn't matter, it runs fine. WHAT THE HECK? HELP!
What work has been done to the car recently? This usually happens when there is a bad ground to the PCM (G101, is the main ground for the PCM).
(Post 373880)
G101 on the v6's is a bit hard for me to describe - never personally put my eyes/hands on it. Plus if no one have been around the engine bay - It would seem the issue is not with G101 as it is on the drivers side of the engine around the throttle body area.
Based upon the new head unit, yes I would look around in that area to start. |
(Post 373902)
Based upon the new head unit, yes I would look around in that area to start. I was able to tighten it with my 10mm socket with an extension. Didn't have to remove anything to do it, but it is moderately obscure so there was a bit of finger-feeling to guide the wrench onto it. I'll know this afternoon if it solved all my problems. Thanks a ton poorman212! |
Were you able to see it? Sometimes the wires & ring-terminal are corroded, which adds to the problem.
Originally Posted by JimBlake
(Post 373953)
1 Attachment(s)
So since you go it tight has the car been acting better?
If you could I would love to see a pic of it, the one in the service manual for the v6 is very vague and hard to describe to someone so an actual pic would be nice |
(Post 373975)
If you could I would love to see a pic of it, the one in the service manual for the v6 is very vague and hard to describe to someone so an actual pic would be nice I got a few good pics. Now if i can figure out how to post them. Give me few. |
3 Attachment(s)
(Post 373975)
