Accord 94, A.T. problem. Need Help
Old Jun 18, 2006 | 01:59 PM
amigoxp
Default Accord 94, A.T. problem. Need Help
Hi
My Automatic transmission slip on all position, except in reverse with a delay. The filter and oil are new. The oil is red and smell nothing special. Last detail, many time the odometer display a bad speed and the cruise control run erracticly.
Is it the clutches, VSS sensor .... ???
Thanks for your help
Old Jun 20, 2006 | 04:23 AM
lightshow's Avatar
Default RE: Accord 94, A.T. problem. Need Help
any check engine lights on? does the d light flash?
Old Jun 20, 2006 | 09:02 AM
YeuEmMaiMai's Avatar
IF your D4 light is flashing, then yes the VSS is MOST LIKELY the problem. IF your trans is slipping in all gears, it could be something like a bad trans pump
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
kellysa111
May 1, 2009 08:35 AM
kwp1229
Sep 22, 2005 04:57 PM
krustyfire
Sep 17, 2005 12:47 AM
