accord cams
Old Jan 20, 2008 | 01:02 AM
BlkCurrantKord's Avatar
Default RE: accord cams
ORIGINAL: nafango2
why would you put forged rods and pistons in a non-turbo engine?
Huge shot of nitrous. Better product than a cast material. The S2000 has forged pistons from the factory.
Old Jan 22, 2008 | 03:18 AM
YeuEmMaiMai's Avatar
get some CL type S cams and call it a day
building up a J30a is pointless unless you are going to FI it and even then the stock internals can handle what the S/C can feed it even on the high boost pully
Old Jan 22, 2008 | 09:27 AM
falkore24's Avatar
Gentlemen .... a cam is an oblongated circle! The V6 has 18 cams and 2 camshafts.
Old Jan 22, 2008 | 09:50 AM
marbro's Avatar
touché, but now youre just pointing out technicalities ^_^
Old Jan 22, 2008 | 11:06 AM
falkore24's Avatar
all in the name of accuracy!!!! I'm a specifying engineer, what do you expect?!? In my line of work, the details will make or break you!
Old Jan 22, 2008 | 03:00 PM
marbro's Avatar
well... when someone asks how to design a camshaft because they are going to make one themselves have at it ^_- but buying one that someone else designed... psh... forgetaboutit ^_^
Old Jan 22, 2008 | 04:07 PM
  #17
falkore24's Avatar
I don't necessarilly agree with that, but you do need to know what you're getting. I'm not going to orderr a custom grind when I boost my tc, but I'll do the research to figure out the specs that I want and find what has already been developed and compare notes. Chances are pretty good that whatever I come up with is going to be pretty close to what's already been developed ..... but then again, now I'm debating between FI and NA. For NA, I'd definately void my warantees. The TRD SC when installed at Toyota maintains the warrantees. I've found parts that allow my engine to spin up to 9500 rpms and deep dish pistons at 9.0:1 CR and domed ones that give 11.0:1. The TRD sc is made to not hurt the stock internals, but if I change the internals, then a turbo makes a lot more power. Tough choices, but a great problem to have! I love having a tuner's platform to work with!!!
Old Jan 23, 2008 | 08:38 AM
  #18
marbro's Avatar
i only say what i did cause if you goto any decent company that does cam regrinds or full billet cams if they actually have a clue and are using tested and proven designs youre going to get lifts and durations based on your application.... hence the reason i said what i did.... is it a good idea to research what you need? why yes... it is... cause you dont want to blindly assume that the guy youre going to knows whats going on.... and you could end up with a nice 360degree duration and a lift that destroys your valvetrain ^_^
Old Jan 23, 2008 | 08:48 AM
  #19
falkore24's Avatar
^^^ my point exactly!!! ..... I'd just feel more comfortable with a design that has been replacated, tested and proven for the application.
Old Jan 23, 2008 | 09:37 AM
  #20
marbro's Avatar
my goal is just to be able to find a cam from an f23 engine....... i still have yet to find a junked out accord : o/ i would have had a cam with a turbo grind for the last 4 months had i found one
Go Honda GO
Apr 13, 2007 07:24 PM
xVTECx
Apr 1, 2007 04:56 PM
02BlueAccord
Nov 29, 2006 03:40 AM
no_doz
Jun 14, 2006 12:27 AM
TedsF23accord
Jan 18, 2006 12:01 PM
