adjust of idle.....
Old Apr 25, 2006 | 06:32 AM
darryltravis's Avatar
Default adjust of idle.....
Thank you to all for the invaluable info about my problem with the cluster dilemma. I have changed wires and plugs, cleaned the IAC valve and now the engine completely smooth....but the idle speed is about 700RPMS. The engine sounds like it is laboring. I understand that the idle may need adjustment. Do I also reset the ECU? What are the steps to setting the new idle speed and when do I disconnect the IAC....and when do I reset the ECU? Thank you, Wheel, Lightshow, Deserthonda and Marbro.
Old Apr 25, 2006 | 01:02 PM
mbo1985's Avatar
Default RE: adjust of idle.....
Shouldn't be laboring. 700 is just about where you need to be (+ or - 50 RPMs). There is an idle adjustment screw on the throttle body, but you're within specs. Tell us more about this laboring...
Old Apr 26, 2006 | 01:14 AM
Thanks again to this forum....I cleaned the IAC valve and reset my ECU and each time I drive it gets better and better.
the cyclops
Jul 29, 2011 11:25 AM
gigem891
Mar 3, 2011 08:10 AM
ledlaptop
Oct 23, 2009 06:15 PM
fireballer44
Aug 26, 2006 05:48 PM
meazz1
Mar 24, 2006 04:22 AM
