Aftermarket cam gear
Havnt really been able to find too much info on an aftermarket cam gear for my f23. What do you guys think of this mod (pros/cons)? Also my understanding is that you cant just slap it on, it has to be tuned before youll see any gains...
More bolt-on stuff like a header & an exhaust system, I guess.
It would probably make more sense for you to think about your overall goals & budget. If you will eventually get a turbo, then don't waste money NOW on exhaust.
If you will eventually autocross (or some other kind of sanctioned racing) then you should carefully read the rules so you know what's allowed. And what will put you into a higher class where you can't afford to be competitive.
5hp, with a loss in low end power and a gain in high end power is the logical guesstimate. It really doesn't do much except look good and add a tad bit of sound. If you have any plans on going turbo at some point, don't spend your money. YOu'd have to upgrade to a turbo manifold anyways.
