aftermarket pistons
Old Nov 7, 2010 | 09:20 PM
mattz's Avatar
Default aftermarket pistons
Shooting for 400, can i use the stroker pistons on the f22 rods or h22? The 2.3 pistons right?
Old Nov 8, 2010 | 06:15 AM
g22cd5's Avatar
Supper Moderator
It’s doesn’t matter if it's a 2.3l it matters what size the piston is. The liters are calculated by stroke and bore. (exp. h22 engine/ 87mm x 90.7 stroke makes it a 2.2l vs. f22 85mm bore x 95mm makes it a 2.2l)
h22 is 87mm bore so no they will not work.
Old Nov 8, 2010 | 07:52 AM
mattz's Avatar
I meant if i use the stroker pistons i have to use h22 rods right? Thats what i have read.
Old Nov 8, 2010 | 07:59 AM
g22cd5's Avatar
Supper Moderator
ohh sorry I miss read your last post. Yes you want to use h22 rods...they are much stronger than the f22 one's also. If you want aftermarket eagle makes h22 rods for 325bucks shipped to your door off ebay. Not a bad deal for good set of rods...just make sure they come with ARP rod bolts tho...you don't want to use OEM
Old Nov 8, 2010 | 08:38 AM
mattz's Avatar
Well i guess it just comes down to what pistons will get me to 400 safely and cheapest. I guess i'll start looking on dsm forums too
Also im guessing there is no other oem pistons that are interchangable and withstand 400hp
Old Nov 8, 2010 | 08:46 AM
roger lee's Avatar
Dear Sir,
I am going to sell my 2007 honda accord se sed 4dr. would you do me a favor ?
if possible, could I have free carfax report with S/N : 1HGCM563X7A168413.
My email is dhlee2008@gmail.com. Thanks
Old Nov 8, 2010 | 08:54 AM
g22cd5's Avatar
Supper Moderator
Not that I know of. Most OEM pistons the ring lands are the weak point. That why when you start adding lots of pressure to each cyl you want to go with something that is stronger. But less than 400buck for JE pistons is pretty cheap..concerting that most aftermarket pistons range in the $500+ area
Old Nov 8, 2010 | 08:56 AM
g22cd5's Avatar
Supper Moderator
Originally Posted by roger lee
Dear Sir,
and who are you asking??...and why do you think we can do this for free?
Old Nov 8, 2010 | 09:09 AM
mattz's Avatar
is it 4g63 pistons or specifically the stroker pistons?
Old Nov 8, 2010 | 09:23 AM
g22cd5's Avatar
Supper Moderator
I BELIVE it's the stroker piston. I will have to look into that. If you find out yourself plz share cus I would like to know too.
