any low temp thermostats?
Old Jul 23, 2007 | 09:36 PM
noboundaries6289's Avatar
Default any low temp thermostats?
hey all, my car starts to overheat in bumper-to-bumper traffic. I was thinking if I got a lower temp thermostat, this would solve my problem. I think the stock thermo fully opens at 192'F. Would 170' be too low? How bout 180? It doesn't overheat, but does go 3/4 of the way to the "H".
PS: Radiator fluid and coolant are normal, as for fan operation.
Thanks for the replies
Old Jul 23, 2007 | 10:06 PM
marbro's Avatar
Default RE: any low temp thermostats?
and is your water pump working properly?
Old Jul 23, 2007 | 10:11 PM
smaglik's Avatar
second that...
in any event, unless you are just going to drive it to the ground, which i dont think you are...i would go through the effort of fixing it right, not just rigging it up...
Old Jul 23, 2007 | 10:15 PM
new Honda water pump and belts also
Old Jul 23, 2007 | 10:23 PM
smaglik's Avatar
have you replaced the cap?
Old Jul 23, 2007 | 10:30 PM
not the radiator cap, still OEM. Should I get a Greddy cap or Apexi?
Old Jul 23, 2007 | 10:43 PM
smaglik's Avatar
i think another oem would be fine...but i would defintely change it...if your system is not pressurizing properly, that could cause it to overheat...
Old Jul 23, 2007 | 10:46 PM
I think I'll get an Apexi, I think it looks pretty good. I'll give it a try. thanks for the help
Old Jul 23, 2007 | 10:47 PM
smaglik's Avatar
np...hope it works...either way, its a cheap item
Old Jul 23, 2007 | 10:58 PM
just curious, what does np mean?
