best ways to boost low end torque?
ORIGINAL: Velocifero
but who would do that?
ORIGINAL: 00AccordLX5spd
If you have a header, take it off and put the stock manifold back on.
wet nitrous FTW!!!!! [sm=nxsmile.gif] $500-750 depending on options and you set your gains! A 4-cyl is good for a 50HP setup safely. I have a friend that is pushing a 90 dry shot through a 98 Civic EX! That car has a few mods that allow that though (multiple electronic upgrades and parts, 260 injectors, custom ported Skunk 2 IM, 72mm TB, performance headers & exhaust, etc.) ....... for the guys that have read my past posts, this is the crazy master machinist that pours custom bushings. ..... the car can also handle a 1.3 g turn!!!
Neither turbo nor nitrous would help with low end torque though. You can't even (or you shouldn't)spray nitrous in 1st gear and the turbo has to spool up. Plus they are neither cheap nor easy[:'(]
I don't think there is a whole lot of options for boosting low end torque without spending a fair amount of cash. You could re-gear the tranny, a new tuneable computer could help, maybe an adjustable cam gear and advance it just a little...
'97 EX wagon (2.2 VTEC auto)
Satisfied with the adequate hp for a family hauler. Mostly want more oomph btw 2K-3K before the lift shift. Not looking to outlaunch M3s or anything, just add to passing ability & freeway merge w/o dipping into the gas-sucking high-lift cam profile, so maybe 30-40 ft-lbs. I also am concerned about passing the under-hood emissions visual.
Owned a T-Bird SC & so I know a supercharger will do it - any products for this application that anyone is aware of?
What have you all experienced from a turbo...on the 2.2VTEC?
Ram air? I saw that the short tube only pulls from under hood. Adequate or is a long run the much better option & where does it pull from?
Will a anything mentioned get the MVD grumbling?
Lastly, what's the cost for chip replacement & how bulletproof is it? I've got 117K on the clock & would like to double that like my last one did (90 CRX base 1.5)
If I can get torque up, I am considering re-gearing the tranny down some so that it runs under 3K at 85 mph. Anyone done something similar?
