CEL problem
Old Mar 10, 2008 | 11:18 PM
steviebix's Avatar
Default CEL problem
can someone tell me ALL the possible reasons why the chk eng light can come on? is it only related to the 02 sensors? i think i heard that somewhere...
[align=left] [/align]
Old Mar 11, 2008 | 12:15 AM
Slusher's Avatar
Default RE: CEL problem
CEL can be more than O2 sensors. Take it to autozone or another place that will read codes for free. You can also jump a connector under the glove box to read the blinks of the light. You might want to do a search on here for CEL and how to read them, I'm not sure about your year of car if it is all the same.
Old Mar 11, 2008 | 09:26 AM
00AccordLX5spd's Avatar
Registered User
Seriously,look in the DIY section: https://www.hondaaccordforum.com/HON...m_15108/tm.htm
Here's a list of ALL the codes for your car: http://www.troublecodes.net/honda/hondaobd2.shtml
I see 124 codes listed there. No one is going to take the time to list all those out.
FYI: From what I see, there are only 16 of 124 codes that are caused by an o2 sensor. Whoever gave you that info is dead wrong.
Old Mar 11, 2008 | 11:52 AM
Not only that, but each of those 124 codes simply narrows it down to a system, not necessarily a single definite problem. So there's hundreds & hundreds of actual REASONS for it to go off.
Old Mar 11, 2008 | 03:17 PM
steviebix's Avatar
code P0740, AT concerns. my trans slips and slides ALL over th place, hence all my other trans posts. Time for a new AT. (sighs)
Old Mar 15, 2008 | 10:42 AM
Chiovnidca's Avatar
ORIGINAL: steviebix
The transmission code of death.....
Old Mar 17, 2008 | 12:21 AM
steviebix's Avatar
really? what exactly does that code mean, chio?
Old Mar 17, 2008 | 04:32 PM
steviebix's Avatar
bump. what does that code signify?
Old Mar 17, 2008 | 04:58 PM
Start saving for a replacement tranny. I'm no expert on auto trannys, so hopefull someone else can chime in.
Old Mar 17, 2008 | 08:40 PM
Chiovnidca's Avatar
ORIGINAL: steviebix
It points to the converter lockup circuit in the transmission. There's a screen in there that gets clogged up from all the worn out clutch packs causing low fluid pressure. A rebuild is the only way to repair it.
