checklist for h22a engine+trans swap HELP!
Old Feb 15, 2007 | 01:22 AM
noboundaries6289's Avatar
Default checklist for h22a engine+trans swap HELP!
Hey all, I'm thinking of a complete engine and trans swap. Setup now: f22b1 4-speed Auto. Desired: H22a 5-speed manual. I can get engine+trans+mounts+driveshaft. ect. for $2300. Any labor $$$ estimates? and what else do I need for this tranny swap? peddals, linkages? thanx.
ps: will the swap even be worth the time and money?
Old Feb 15, 2007 | 01:41 AM
Slusher's Avatar
Default RE: checklist for h22a engine+trans swap HELP!
The swap will be worth the money if you want 200 hp and a stick. Your gonna need the pedal set up, clutch master cylinder, shift linkages, ecu, sensors, etc. I think that it is worth it but depending on the shop, you could be looking at around a grand for labor; I think that is a high figure and maybe someone who has done it could say otherwise but it is a pretty involved process especially when the car is going from auto to manual.
Old Feb 15, 2007 | 01:18 PM
Thanx for the info. Will I have to change out my gauge cluster? Or is it optional. Im savin up for it now. I also called AAMCO transmissions, (out the door expensive!) $2500 just in labor. thats with me supplying the parts. But, thats a corp. I also know a family shop, havn't called them yet.
PS: CRAP! I found a crack in the top of my radiator. there goes another $200-$250. Should I buy a single core or dual core radiator (tasauto.com) Labor=$100 Single=$116.00 Dual=168.00
Old Feb 15, 2007 | 01:49 PM
sir_nasty's Avatar
I don't know on the radiator for sure.... but what I can tell you is that it's easy to change, do the radiator job yourself... don't forget your motor mounts when you go to install the h22a....
Old Feb 15, 2007 | 01:55 PM
can someone email me instructions and maybe some pics on how to do this? (radiator job) thanx
cj16_007@yahoo.com
Old Feb 15, 2007 | 02:06 PM
sir_nasty's Avatar
I won't e-mail it but I'll post it *L* here's the instrucitons from my 94, should be nearly identical, if you have a digital camera keep it handy, if you run into a snag you can post pictures of what's holding you up and get more help....
[IMG]local://upfiles/3079/C142C6FA7D1946FAA99AFE34B09A297F.jpg[/IMG]
StrikingAccord
Jul 3, 2011 03:55 PM
abit2theright
Feb 14, 2008 09:57 PM
hitek85
Feb 12, 2008 10:32 AM
ncsgoofy
Aug 5, 2006 08:08 PM
hawzmolly
Nov 9, 2005 04:19 AM
