Is this correct A/C operation?
When A/C is on, the A/C and Radiator fans start cycling on and off every 10 seconds or so (simultaneously), whether the temp is cold or hot, just started or been on for a while.
Is this correct operation? It is of course still under warranty i was gonna take it to Honda for my 20,000 mile service soon, but, i would like to know if this is expected operation or not. Thanks |
RE: Is this correct A/C operation?
fan cycling has to do a lot with ambient temperature, the hotter it is 90-100 degrees, the more and sooner the fans will cycle .. if it is cold temp and it still cycles every 10 seconds ,,
it is a bit too soon,, |
yea when your fans and compressor turn off it is the defrost cycle for your evaporator. they should do this.. if it really is every 10 seconds then i think that may be a little too soon. i have seen some cases where low freon level will make the system cycle very often like that.
