Dart B18/B20 replica blocks
Old Mar 2, 2008 | 06:17 PM
Obsessed_Tuner
Default Dart B18/B20 replica blocks
I didn't see any posts on this so i thought i'd start a thread.. its interesting reading... Dart Machinery is producing finer grade B18 and B20 blocks. Anyway, just read on... i provided some more informational links toward the bottom. I think i just found a new project!!
• Dart B18 block has stock deck height, standard 81.5mm bore, optional 84.5mm bore.
• Dart B20+ block has extra-tall 8.900" (226mm) deck height, 84.5mm bore for increased displacement.
• Manufactured from aerospace quality C355-T6 virgin aluminum alloy for maximum strength and durability.
• Replaceable ductile iron dry sleeves are fully supported to reduce bore distortion andenhance ring seal.
• Closed deck design increases rigidity and improves head gasket
sealing.
• Steel main caps with high-strength bolts increase bottom end strength and minimize bearing bore distortion.
• Extra large water jackets increase coolant circulation around cylinders.
• Standard piston oil sprayers reduce piston temperatures to extend life and prevent detonation.
• Dart blocks use stock components, including oil pan, oil pump, water pump, alternator, and timing belt tensioner.
http://www.dartheads.com/hondab.aspx
http://www.dartheads.com/hondah.aspx
http://www.hondatuningmagazine.com/t...ht_tenaciousb/
http://www.hondatuningmagazine.com/t...04ht_bastardb/
-Taken From Superhonda.com
Old Mar 2, 2008 | 07:02 PM
BlkCurrantKord's Avatar
Default RE: Dart B18/B20 replica blocks
Spam?
Old Mar 2, 2008 | 09:15 PM
finch13's Avatar
Sounds like spam, but is still interesting for the more serious Civic dudes... I hope he doesn't really think us Accord owners are going to do a B-series swap...
Old Mar 3, 2008 | 06:42 AM
DART blocks have been around for years. It's not exactly new news.
Old Mar 4, 2008 | 07:31 PM
marbro's Avatar
that engine would be awesome on a gocart ^_^
Kskna
Aug 13, 2015 06:22 AM
89lxi/jdm junkie
Feb 23, 2012 12:40 PM
deadaccord92
Apr 19, 2011 01:10 PM
bbklover
Feb 12, 2006 02:11 PM
