-   Engine & Internal (https://www.hondaaccordforum.com/forum/engine-internal-11/)
-   -   ECU Question (https://www.hondaaccordforum.com/forum/engine-internal-11/ecu-question-8919/)
sssexy70 Apr 14, 2007 05:53 PM
ECU Question
I know this is redundant to ask since it has appeared before on this forum, but having just installed my short ram on my 1997 accord 4cyl, I want to reset the ecu without pulling the battery. How do I find the fuse to reset it? I don't know which fuse the back-up is...
03Sleeper Apr 14, 2007 06:05 PM
RE: ECU Question
I just disconnected the negative terminal and the ECU is reset (or maybe not...correct me if I'm wrong). It's just a simple remove the washer from the bolt, let it sit for 5-10 minutes, reconnect, and test.
But for the fuse...I have no idea. I've always thought about it...but could never find it.
deserthonda Apr 14, 2007 07:17 PM
RE: ECU Question
go to the DIY section ( how to reset ecu )
sssexy70 Apr 14, 2007 07:18 PM
RE: ECU Question
I did and it doesn't help... I don't know how to find that specific fuse...
deserthonda Apr 14, 2007 07:25 PM
RE: ECU Question
ORIGINAL: sssexy70
underhood fuse box , back up fuse 7.5 amps ,, you could not find it ?/ furthest fuse to the top right
sssexy70 Apr 14, 2007 07:26 PM
RE: ECU Question
thank you, found it
Fenix Apr 14, 2007 08:08 PM
RE: ECU Question
now thats some excellent help DH
03Sleeper Apr 15, 2007 12:31 AM
RE: ECU Question
DH's new avatar confused me for a second since I am so used to seeing Bond.
I was like woahhh...who's that guy...why is Bond a robot! Ohhhhhh....:p
theBrewMeister Apr 17, 2007 06:46 AM
RE: ECU Question
Yeah, Im with desert on the fuse pull reset, simply becuz I hate having to DC the battery for any reason. I hate having to reset all my head unit settings. So the fuse pull method is definitely the way to go.
deserthonda Apr 17, 2007 09:57 PM
RE: ECU Question
ORIGINAL: 03Sleeper
bond is an a mission for a while , so he asked his friend to sub in for him ;)
