Engine Long Block
Old Sep 1, 2009 | 03:29 AM
vana's Avatar
Banned
Default Engine Long Block
MARSHALL ENGINES PREMIUM PLUS LONG BLOCK ENGINE, REMANUFACTURED -- SOHC, non-VTEC, engine code F22B2, 16 mm crank snout bolt; Includes factory installed oil pan, timing cover, oil pump, pick-up tube and screen, and gasket set; Cylinder heads are bake cleaned and shot blasted; Features high quality seals, installed valves and springs and 3-angled cut on valve seats; 100 percent mag inspected and pressure tested, vacuum tested for perfect seal, decks milled and surface checked, final oil pressure bench-mark tested on OHC heads, camshaft and followers installed;
NO SPAM
HondaBill
Jul 16, 2012 07:15 PM
dman8-1-14
Mar 6, 2011 11:47 PM
yeaaa
Aug 10, 2008 08:21 AM
david76008
Mar 30, 2007 03:24 AM
silverbullet2006
Jul 1, 2006 05:04 PM
